97 civic will not start
Old 02-03-2013, 05:50 PM
fredo818
fredo818's Avatar
fredo818 has disabled reputation
Default 97 civic will not start
I have a 97 honda civic coupe with a 99 gsr swap. Up until recently the car worked fine but the other day when I tried to start it nothing happened. The accesories wont even work. I tried jumping it and swapping out the battery as well. I also changed the battery terminals because they looked old and I checked the fuses and grounds and everything checked out good. Anyone know what can possibly be the problem? Everything I find is on cars that will crank but wont turn over. This has the symptoms of a dead battery but its not. I did lock the keys in the car and they were stuck in the ignition for a while. Would that have ruined something?
fredo818 is offline
Old 02-03-2013, 06:05 PM
Dillweed
Dillweed's Avatar
Dillweed Dillweed Dillweed Dillweed Dillweed Dillweed Dillweed Dillweed Dillweed Dillweed Dillweed
Default Re: 97 civic will not start
battery and starter circuits. multimeter.
And last question seems stupid.
Dillweed is offline
Old 02-03-2013, 06:06 PM
fredo818
fredo818's Avatar
Just trynna be as detailed as possible because it was fine and after that happened was when the problem started
fredo818 is offline
Old 02-03-2013, 06:09 PM
Alkaline8214
Fence Hopper
Alkaline8214's Avatar
Alkaline8214 Alkaline8214 Alkaline8214 Alkaline8214 Alkaline8214 Alkaline8214 Alkaline8214 Alkaline8214 Alkaline8214 Alkaline8214 Alkaline8214
Check wires on the starter.
Alkaline8214 is offline
Old 02-03-2013, 06:21 PM
Dillweed
Dillweed's Avatar
You need to see what voltage you are getting at the battery, voltage at the starter, inspect the clutch safety stitch, and check for high resistance at various conections in question. Never test for resistance with the battey in load.
If you think you broke the igniton switch, then you should get one; if that's what you're trying to say.
Dillweed is offline
Old 02-03-2013, 06:26 PM
Dillweed
Dillweed's Avatar
A simple Haynes book for a civic or integra will help you a lot if you don't know what you are doing.
Dillweed is offline
Old 02-03-2013, 07:41 PM
00_civic757
00_civic757's Avatar
00_civic757 has disabled reputation
did u check the relays while u were checking the fuses and grounds?
00_civic757 is offline
Old 02-15-2013, 09:18 AM
crxmatt
crxmatt's Avatar
crxmatt crxmatt crxmatt crxmatt crxmatt crxmatt crxmatt crxmatt crxmatt crxmatt crxmatt
Also check fuse 15 and see if its blown there's a tsb on it
The wiring shorts out under the intake manifold this shouldn't
Cause the car to not start but may be the reason the battery may not
Be charging. Check the little ground wire on the starter too over time
The connectors wear out and makes the wire pop out and will cause it
To not start had that happen on 2 of my civic before
crxmatt is offline
Old 02-15-2013, 09:21 AM
errikd
errikd's Avatar
errikd has disabled reputation
Check your headlight fluid. Sounds like the problem
errikd is offline
Old 02-15-2013, 09:25 AM
grgazn
fuck this shit
grgazn's Avatar
grgazn grgazn grgazn grgazn grgazn grgazn grgazn grgazn grgazn grgazn grgazn
Alright Frodo, all you need is to check a few fuses and check your ecu. If it was left in accessory mode it could have shorted something. Also, check grounds. If you actually need intelligent help, +rep me and pm me. Ill help ya out.
grgazn is offline
Quick Reply: 97 civic will not start
