2005 Subaru Legacy GT Limited ABP (Stuarts Draft, VA)
[ATTACH=CONFIG]173725[/ATTACH][ATTACH=CONFIG]173726[/ATTACH][ATTACH=CONFIG]173723[/ATTACH][ATTACH=CONFIG]173727[/ATTACH][ATTACH=CONFIG]173724[/ATTACH]
ABP (Atlantic Blue Pearl)
5eat ( 5 Speed Electronic Automatic Transmission)
143,XXX Daily Driven
Limited Edition,
Heated Seats, Mirrors, and Windshield Wipers.
Black Leather Interior ( Seats F&R, Trimmed Steering Wheel, and E-Brake Handle)
Phototronic Rear View Mirror ( Dims when headlights are detected)
17" Limited Wheels W/ Kumho Exsta ASX with plenty of tread.
6 Disc In-Dash CD Changer
3000K Yellow Projector Fog Lights
Brushed Aluminum "Look" Front Grill
Plasti-dip Black Badges (Easily Removed)
Factory EJ255 Turbo Boxer, 2005-6 Actually shared the same short block with the familier WRX STi, this rated at 250hp 250tq Factory
STi Close Ratio Steering Rack.
Aftermarket:
BNR 16g Evo 3 Big Compressor Wheel
CNT Racing Catted Downpipe
CNT Racing Cattless Up Pipe
CNT Racing Quad-Tip Cat-back Exhaust (Just barely louder than SPT)
Perrin Turbo Inlet
AVO Throttle Body Hose
"Bullet Proofed Intercooler" (Aluminum Channel and Steel Ties around the seems)
Mr Gasket Turbo to IC rubber gasket
IPT Turbo Oil Supply Lines With 10 Micron In-Line Filter
Only had Rotella T6 in it since the Turbo Swap 3500 miles ago.
Cobb AccessPort V2
E-Tuned by Eric at Torqued Performance
19.5psi +/- .5 Conservative Timing
Guestimating by the Cobb and Virtual Dyno Around 260whp 310wtq
Definitly more to be had with supporting Fuel System.
Car has been driven out of state multiple times and done very well. Rides Great and still gets 27-28mpg on long trips with the larger turbo. The Turbo should still be under warrenty at BNR and is transferable. Car runs very well and is not for a first start driver.
Asking $11,995 OBRO
If it doesn't sell in this condition i will be reverting back to stock.
540-471-7965 Text/ Call after 5pm
Still owe on car so trade can only be for 3Kish or less + Cash.
Limited Edition,
Aftermarket:
Perrin Turbo Inlet
Cobb AccessPort V2
Asking $11,995 OBRO
Re: 2005 Subaru Legacy GT Limited ABP (Stuarts Draft, VA)
BUMP. Check it out.
Bump
BlackOnBlackGT
05-17-2010 04:51 AM
