blown head gasket????
Old 01-01-2007, 03:38 PM
b16efhatch
b16efhatch's Avatar
b16efhatch has disabled reputation
Default blown head gasket????
ok, so I put a b16a in my 89 si hatch and the first time the gasket was put on upside down. so I sent the head to the machine shop and they fixed the head. I finally got around to putting the head back on today. I put the timing belt on and I couldnt get it to tighten, and at the same time I had 2 of the plug wires swithed around. I fixed the plug wires and got the timing belt to tighten after a long attempt of trying to get it to start. Well I got it to start and it runs but horribly rough and know the head gasket is blown(has a white milky texture to it) and Im not sure why. does anyone know what could have happened
b16efhatch is offline
Old 01-01-2007, 03:41 PM
b16efhatch
b16efhatch's Avatar
Default Re: blown head gasket????
it is also throwing an engie code, its #5
Old 01-01-2007, 03:46 PM
integrarj
integrarj's Avatar
did you torque the head to the right specs
integrarj is offline
Old 01-01-2007, 04:28 PM
b16efhatch
b16efhatch's Avatar
yes everything was torqued properly(head, cam caps,rods mains...ect)
Old 01-01-2007, 04:41 PM
Vern
turbo on 2 wheels
Vern's Avatar
Vern Vern Vern Vern Vern Vern Vern Vern Vern Vern Vern
did you put the same head gasket back on it? the one that you took off that was upside down?
Vern is offline
Old 01-01-2007, 04:42 PM
93civicgone
Tattoo man
93civicgone's Avatar
93civicgone has disabled reputation
your prob off time reall bad and compression is all screwed up
93civicgone is offline
Old 01-01-2007, 04:44 PM
EvolutionBoostin
Currently N/A
EvolutionBoostin's Avatar
EvolutionBoostin is an unknown quantity at this point
You need a new head gasket. Can't re-use the other one.
EvolutionBoostin is offline
Old 01-01-2007, 05:48 PM
CHAHONDA
corona connessuer
CHAHONDA's Avatar
ditto!
CHAHONDA is offline
Old 01-01-2007, 06:19 PM
b16efhatch
b16efhatch's Avatar
put nwe head gasket on and car is timed properly
Old 01-01-2007, 07:09 PM
Dang Yo
Justa lil 6
Dang Yo's Avatar
Dang Yo is a jewel in the roughDang Yo is a jewel in the roughDang Yo is a jewel in the roughDang Yo is a jewel in the roughDang Yo is a jewel in the rough
rods and mains arent in the head.
Dang Yo is offline
Quick Reply: blown head gasket????
