b16a sounds wrx
b16a sounds wrx
i have a b16a swap in a 94 eg coupe. it starts perfect and idles perfect. when i start driving it sounds like a wrx. i been told a lot of things but would like tech help pleaseeee
Re: b16a sounds wrx
My friend had an h22 that sucked in some water, and ended up snapping a rod and bending some valves.
Sounded just like a WRX, right after it happened.
БЛЯДЬ!
Re: b16a sounds wrx
A loose spark plug in the cylinder
Incorrect firing order (plug wires are not correctly plugged into the distributor or to the correct cylinder)
and this
and this
