ek with z6 swap
Old 09-02-2010, 02:26 PM
brondon1990
brondon1990's Avatar
brondon1990 has disabled reputation
Default ek with z6 swap
ok so i did a z6 swap into my 2000 civic coupe. to get past the dizzy issue i just took my obd2 distributor and threw on the z6 head. (prolly not right not really sure) did notice that it didnt exactly bolt up correctly but i rigged it up so that it would. now it starts but runs really rough and my cel light comes on. any suggestions? oh also for some reason i can shift into a gear and leave my parking break up then let go of the clutch and the motor wont choke off. HELP please!!! thanks in advance
brondon1990 is offline
Old 09-05-2010, 04:22 AM
ShortStackSoJDM
EMPIRE
ShortStackSoJDM's Avatar
ShortStackSoJDM has disabled reputation
Default Re: ek with z6 swap
1. do it right and get a z6 dizzy with a 0bd2-obd1 jumper harness and the correct ecu (p28) with the jumper harness. realize your running the wrong dizzy with that head and that prolly why ur cel is on and its running bad. i have the same setup in my car with a jumper harness at the dizzy and the ecu. runs perfect.
2. ur e break is prolly worn. pop the center console off and see if you can tighten it up.
ShortStackSoJDM is offline
StermeR
Honda
31
11-02-2010 03:16 PM
broke94hatch
01-22-2010 07:40 AM
morenolindo
10-08-2009 03:21 AM
GreenSalesman
12-30-2008 03:25 PM
Quick Reply: ek with z6 swap
