running rich
Old 06-15-2006, 01:57 PM
Tito
Bro'd Out
Tito's Avatar
Default running rich
my car start running rich yesterday and sometimes hesitates when i am accelerating. i had the same problem with my tiburon and it was the throttle position sensor, what do you guys thing.
95 teg by the way.
Tito is offline
Old 06-16-2006, 03:40 PM
King Dingaling
Big Dick Playa
King Dingaling's Avatar
King Dingaling King Dingaling King Dingaling King Dingaling King Dingaling King Dingaling King Dingaling King Dingaling King Dingaling King Dingaling King Dingaling
Default Re: running rich
take it to a shop, or a friend with something that can read your ecu and watch the real time activity such as o2 sensor voltage tps voltage map voltage etc. im sure something in there is starting to give up.
King Dingaling is offline
Old 06-16-2006, 10:52 PM
Tito
Bro'd Out
Tito's Avatar
yeah i figured i'd get aroudn to that eventually, it has been running more normal as of late. my dad has something that read's codes from OBD2, but the car is OBD1
Tito is offline
Old 06-17-2006, 02:54 AM
Jarrod
braap braap
Jarrod's Avatar
You didn't state if it was throwing any codes, so I assume no?
Do like Mark W said. A friends car recently did this, and we checked the TPS and it needed to be reset. After that, the bucking went away.
Jarrod is offline
Old 06-17-2006, 05:10 AM
Enigma
Enigma's Avatar
Check your ECU to see if it is throwing codes. You will have to use a jumper wire to do this. Count the amount of long blinks and quik blinks to find the right code(s) it is throwin, if any. After that get out the voltmeter and have fun
If you are still having trouble and your manual isn't helping, find a tech/guru.
Enigma is offline
99hatchR
01-25-2009 01:51 PM
sive ick
06-13-2007 09:31 PM
Junon
04-12-2006 05:33 PM
Tmac85
06-25-2005 08:59 AM
Black Z-24
08-11-2004 04:28 AM
Quick Reply: running rich
