jdm gsr vs. usdm gsr
Old May 31, 2007 | 04:49 PM
turbofordummies's Avatar
turbofordummies
Reppin The DOHC
turbofordummies turbofordummies turbofordummies turbofordummies turbofordummies turbofordummies turbofordummies turbofordummies turbofordummies turbofordummies turbofordummies
Default jdm gsr vs. usdm gsr
can anybody tell me the differences between jdm gsr and usdm gsr.
thanks
Old May 31, 2007 | 04:54 PM
GRETSRONE's Avatar
GRETSRONE
GRETSRONE has disabled reputation
Default Re: jdm gsr vs. usdm gsr
USDM - 170HP
JDM - 180 W/ LSD
Atlantis's Avatar
Atlantis
OV-104
JDM has 10hp more? Idk all the specs but I believe that is true
Beat me to it
Old May 31, 2007 | 05:02 PM
turbofordummies
Reppin The DOHC
thanks, if i was to put a gsr in my car what can i expect to run in the 1/4? and would i feel vtec more in the gsr as apposed to my single slammer?
Old May 31, 2007 | 05:04 PM
Atlantis's Avatar
Atlantis
OV-104
You'll feel alot more everything down to torque
Old May 31, 2007 | 05:05 PM
turbofordummies
Reppin The DOHC
cool what do i need to make it work in my 98 civic
Old May 31, 2007 | 05:17 PM
GRETSRONE's Avatar
GRETSRONE
ALL DEPENDS ON WHAT YOU DO TO THE MOTOR.
I believe the pistons compression ratio are slight different
udsm - 10:0.1
jdm - 10:6
Old May 31, 2007 | 05:36 PM
Jarrod's Avatar
Jarrod
braap braap
High 14s depending on mounts/clutch/tires and your driving.
If a car is tuned correctly, you shouldn't feel vtec.
Old May 31, 2007 | 05:43 PM
turbofordummies
Reppin The DOHC
am I retarded or did I miss somethin?
If a car is tuned correctly, you shouldn't feel vtec.[/QUOTE]
Old May 31, 2007 | 05:45 PM
JustaGSR18's Avatar
JustaGSR18
I <3 MY EG
JustaGSR18 has disabled reputation
I agree on the Q/M et you suggest, but with a gsr if you don't feel vtec than somethings wrong.
