F/S: Car Audio Componets
Old Aug 30, 2007 | 04:26 PM
edtek's Avatar
edtek
where ma ribbons at?
edtek is infamous around these partsedtek is infamous around these partsedtek is infamous around these partsedtek is infamous around these partsedtek is infamous around these partsedtek is infamous around these partsedtek is infamous around these partsedtek is infamous around these partsedtek is infamous around these partsedtek is infamous around these partsedtek is infamous around these parts
Default F/S: Car Audio Componets
Means of contact: thru Pm or (757)613-9406 or (757)869-0572
Price: (selling as a whole)NEW PRICE250OBO
I am selling Alpine 5-channel (mvrf450)
Info:
Alpine V12 Series 5 Channel Mobile Amplifier - MRVF450/ 240W x 2 + 370W x 1 Bridged 4 Ohms Max Power/ 12V RMS Continuous Power 4ohm/ Bass Engine®/ S/N Ratio 100dBA/ 10-50kHz Frequency Response/ Extra Large Gold Plated Terminals With Wire Insert Capability/ Top Panel Power LED/ DC-DC/PWM MOSFET Power Supply
this is a discontinued Model and runs for 500 still! in great condition!
MTX Thunderfrom Box (made for a 92-95 Civic Coupe)
Info:
Mtx box in good contion(couple of nicks here and there) comes with a '10
Planet audio speaker(Its a 4 year old sub but still hits like it came from that factory)
MTX 10 sub Thunder8000
Info:
Do you have a system in your car that your Grandma would be ashamed of? Well upgrade with this shiny 10" sub from MTX. The injection-molded aluminum cone with NBR rubber surrounds will handle those low-end frequencies while a die-cast aluminum basket holds everything together and provides greater durability. And with 1000 watts of peak power handling
Subwoofer Size : 10 Inch
Dual Voice Coil : No
Impedance (Ohms) : 4
Peak Power Handling (watts) : 1000
Frequency Response (Hz) : 24Hz - 150Hz
Sensitivity (dB) : 83.4
Woofer Cone Material : Injection-Molded Aluminum
Woofer Surround Material : NBR Rubber
Voice Coil Design : 4-Layer, Apical Voice Coil Formers
Basket Material : Cast Aluminum
xMax - Maximum Excursion (millimeters) : 12.2
QTS : .45
Fs - Free Air Resonance (Hz) : 24.2
Recommended Amp Wattage Range : 50 - 200 Watts
Mounting Depth (inches) : 5
Vas (liters) : 33.5
Recommended Enclosure Type : Small Sealed, Bandpass, or Ported
Sealed Box Volume (cu. ft.) : 0.5 - 1.0
Ported Box Volume (cu. ft.) : 1.0 - 2.0
Port Diameter (inches) : 3.0
Port Length (inches) : 16.0
Selling everything as a whole
Price is OBO And will do trades with a B16 Vtec head or Gs-R vtec head
Old Aug 30, 2007 | 06:19 PM
98civicONair's Avatar
98civicONair
tWiStEd wAgOn
98civicONair has a spectacular aura about98civicONair has a spectacular aura about98civicONair has a spectacular aura about
Default Re: F/S: Car Audio Componets
damn good to know you are still alive
Old Aug 30, 2007 | 09:01 PM
edtek's Avatar
edtek
yea, i take hiatus every once in a while!
Old Sep 1, 2007 | 08:20 AM
edtek's Avatar
edtek
up
Old Sep 2, 2007 | 07:51 AM
edtek's Avatar
edtek
penor
Old Sep 4, 2007 | 10:45 AM
edtek's Avatar
edtek
up
Old Sep 5, 2007 | 03:17 PM
edtek's Avatar
edtek
up
Old Sep 21, 2007 | 04:59 PM
frankinstine's Avatar
frankinstine
B20 VTEC
frankinstine has disabled reputation
great guy to deal with
Old Sep 22, 2007 | 03:08 PM
edtek's Avatar
edtek
Bump for a new price!!!!!!!!
Old Sep 24, 2007 | 04:48 PM
majette's Avatar
majette
Blactical Actual.
majette majette majette majette majette majette majette majette majette majette majette
called and sent text msg...
UnityRacing
Other ARCHIVE
11
Oct 18, 2008 08:00 PM
