Complete swap w/wire harness and shift linkage....all oem genuine honda parts. New genuine oem water pump,timing belt,oil pump, oil pan and gasket and crank pulley. Oem genuine honda rear main seal and cam seals, throttle body gasket, and intake manifold gasket. Also with it a 95 gsr OBD1 P72 ECU w/type throtle body and position sensor. If you nedd them, I have a set of 94 integra LS axle cores. To install the motor all you would need is a set of mounts and an O2 sensor.
Asking $1950.00 if you need pictures....they can be provided. Contact Samor Darius @301-642-7094
