EG 6 RIGHT HAND DRIVE CONVERSION.
Old Dec 20, 2008 | 12:15 PM
JDM EG6's Avatar
JDM EG6
JDM EG6 has disabled reputation
Default EG 6 RIGHT HAND DRIVE CONVERSION.
Hey i have been wanting to do a right hand drive conversion on my eg for while now but can't get my hands on a front clip. So i found someone that just sales the firewall and i wanted to now if this would work , do i need other parts ect. Thanks any help would be apreciated. Danny
Old Dec 20, 2008 | 12:19 PM
b16pwrcrx's Avatar
b16pwrcrx
cheeseburger
b16pwrcrx has disabled reputation
Default Re: EG 6 RIGHT HAND DRIVE CONVERSION.
alot more parts than that, ur better off buying a complete clip
Old Dec 20, 2008 | 01:13 PM
aacjohnc's Avatar
aacjohnc
that is not even a quater of the parts your need . buy a front clip .... many places to buy them from jsut google jdm front clip ........ passwordjdm.com is one place . do your research ....
Old Dec 20, 2008 | 02:14 PM
eclispegs2008's Avatar
eclispegs2008
eclispegs2008 has disabled reputation
youll need the steering rack, brake and clutch lines, and many other things (such as the wiring if you want it done right) that affected by things being on the opposite side
Old Dec 20, 2008 | 03:11 PM
Cr33pin's Avatar
Cr33pin
The world is yours
Cr33pin Cr33pin Cr33pin Cr33pin Cr33pin Cr33pin Cr33pin Cr33pin Cr33pin Cr33pin Cr33pin
you would be a fool to buy that...... get a front clip an thank us later
Old Jan 12, 2009 | 11:44 PM
JDM EG6's Avatar
JDM EG6
Old Jan 12, 2009 | 11:48 PM
gotboosthatch's Avatar
gotboosthatch
gotboosthatch has disabled reputation
def need way more than that.. full wiring, subframe, steering column, etc..
you should not buy what you have pictured..
Old Jan 13, 2009 | 02:47 AM
wright's Avatar
wright
You do not need the sub frame to do the RHD conversion but you are right that he will need a lot more to get the job done. He will also need the rest of the interior, steering rack(all parts that so with it), ect.
Your best bet is to find a front cut with everything but the swap and I have seen them go for around 300.
Old Jan 13, 2009 | 04:34 PM
b16EFsedan's Avatar
b16EFsedan
peaches
????????are the brake master cylinders the same??? i was thinking abiut buying a rhd honda but have many concerns on parts and brake lines
Old Jan 14, 2009 | 07:06 AM
wright's Avatar
wright
^^^^^ I am not 100% sure but the brake lines you can one off make them by using braded lines which might cost more. Give Japanese Engine Import a call and Ask for Phil and he should be able to let you know.
