98 integra gsr replacing rear pads
Old Mar 12, 2009 | 03:48 PM
fascelica's Avatar
fascelica
WheelWhore
fascelica will become famous soon enough
Default 98 integra gsr replacing rear pads
IM having trouble replacing my rear brake pads on my 1998 integra gsr. I've taken the 2 12mm bolts on the backside of the caliper and there still seems to be alot more than that to take the caliper off... Any help will be greatly appreciated! thanks!
Old Mar 12, 2009 | 03:53 PM
nftuatn's Avatar
nftuatn
baller/dickbutt#69
Default Re: 98 integra gsr replacing rear pads
that should be it and you need a special tool or at least a screwdriver or piece of steel(like a ruler)to turn in the pistons on the rear...once they are off it will look like a plus sign...they dont push in they turn in
im 99% sure that goes for all hondas
Old Mar 12, 2009 | 03:54 PM
nftuatn's Avatar
nftuatn
baller/dickbutt#69
stick a screwdriver between the ears and GENTLY pry up on the caliper...its most likely has a ridge on the rotor thats holding it on
Old Mar 12, 2009 | 06:19 PM
h22_Lude's Avatar
h22_Lude
h22_Lude has disabled reputation
hit that bitch with a rubber mallot, its only the 2 bolts
Old Mar 13, 2009 | 06:53 AM
fascelica's Avatar
fascelica
WheelWhore
thanks guys +rep
Old Mar 13, 2009 | 06:56 AM
fascelica's Avatar
fascelica
WheelWhore
are there any tricks anyone knows to rotating the piston? that thing is hard as sh!t to turn. i've only been able to get about a 1/4 of a turn out of it in "beast mode" ha??
Old Mar 13, 2009 | 06:59 AM
jt223539's Avatar
jt223539
Sparkle Motion
jt223539 jt223539 jt223539 jt223539 jt223539 jt223539 jt223539 jt223539 jt223539 jt223539 jt223539
Try releasing some of the pressure by opening the bleeder valve, but other then that try harder.
Old Mar 13, 2009 | 07:25 AM
fascelica's Avatar
fascelica
WheelWhore
so you cannot use like a c-clamp to press it in? it can only be spun in clockwise?
Old Mar 13, 2009 | 07:56 AM
NaIsGay's Avatar
NaIsGay
Eh
NaIsGay NaIsGay NaIsGay NaIsGay NaIsGay NaIsGay NaIsGay NaIsGay NaIsGay NaIsGay NaIsGay
yes you are correct, they can only be spun
i normally use a big chisel with vise grips on them to spin it
Old Mar 13, 2009 | 08:42 AM
fascelica's Avatar
fascelica
WheelWhore
thanks +rep
