motor swap
Old May 18, 2009 | 09:29 AM
plasto1's Avatar
plasto1
plasto1 is an unknown quantity at this point
Default motor swap
i have a 1990 ls intgera i was thinking about puting a k20 in it how much work is it to put a k20 into a integra
Old May 18, 2009 | 03:28 PM
~Josh's Avatar
~Josh
doesn't like 1911s
~Josh ~Josh ~Josh ~Josh ~Josh ~Josh ~Josh ~Josh ~Josh ~Josh ~Josh
Default Re: motor swap
first thing that came up on google...
http://hondaswap.com/hybrid-ed-ef-da/k20-into-da-72699/
try searching... i'm sure you'll find something
Old May 18, 2009 | 06:45 PM
accuracy1's Avatar
accuracy1
accuracy1 accuracy1 accuracy1 accuracy1 accuracy1 accuracy1 accuracy1 accuracy1 accuracy1 accuracy1 accuracy1
It's not that it takes that much work, but everything is epensive, and alot of stock parts wont work, so you have to but from Hasport etc. And unless you are lucky, there is the $1,000 dollar engine management you need, just to start the car.
If you did it all yourself, with the cheapest parts avail. I'm thinking it would cost you about 7k for an a2 swap.
Old May 19, 2009 | 04:33 PM
plasto1's Avatar
plasto1
well need my ? is i have the motor i justed to know what all i would need to get to make it fit in the da?
Old May 19, 2009 | 04:34 PM
RameyBuilt's Avatar
RameyBuilt
VAdriven Sponsor
RameyBuilt RameyBuilt RameyBuilt RameyBuilt RameyBuilt RameyBuilt RameyBuilt RameyBuilt RameyBuilt RameyBuilt RameyBuilt
Do some research on h-t and and k20a.org
if u plan on doing it your self i would deffently read up on those sites
Old May 19, 2009 | 07:26 PM
plasto1's Avatar
plasto1
thanks
sTohc4door
Feb 18, 2009 07:12 PM
94jdm_integra
Jun 29, 2008 09:26 PM
