head work tools
DESTROYS DONUTS !!
anybody know a local shop to get a descent set of port and polish die grinder bits, i actually have plenty of porting tools but i need something to polish the head after its been ported, i have two spare heads and im doing a little bit of experimentation, any help would be appreciated cause the fools at lowes and home depot dont know a god damn thing and i havent been to northern to ask them about it.........
i just got done porting my head on the white car. you need a carbide tipped porting tool for alluminum. i personally used one for steel, but had to keep cleaning it cuz it clogged up in the softer metal. Then i used my dremel with a sanding flapper wheel to finish up the ports.
i got plenty of leftover bits and sanding stuff if you need to use them.
DESTROYS DONUTS !!
are you off today ****** cause ill come out to your house and pick those tools up if your not using them and i want to swing by milleniums new shop and check it out and i also need to drop my spare head off to chris so he can dissasemble it so i can get it ready for the new valvetrain.......
DESTROYS DONUTS !!
i have a parts cleaner at the crib that my pops bought, we use mineral spirits in it,i let head soak all night and then i scrubebd it and it came out pretty clean, derek ill cal you tomorrow night , might come out and scoop those tools for a couple days.......
idriveahonda
Mar 10, 2009 06:08 PM
