car shut off on me
Old Sep 10, 2004 | 12:07 PM
JOE-C's Avatar
JOE-C
YourMomIsMyAddiction
JOE-C is an unknown quantity at this point
Default car shut off on me
my car shut off on my ass goin home its electrical i know it cause if i held the starter on and held da gas it would rev up but if i left it on the on position the cluster wouldnt light up can anyone help me out thanks
Old Sep 10, 2004 | 02:51 PM
NIC668's Avatar
NIC668
Default Re: car shut off on me
what kinda car what mods JESUS YOU PEOPLE SUCK AT TRYING TO GET HELP
Old Sep 10, 2004 | 11:46 PM
pimpingreen13's Avatar
pimpingreen13
pimpingreen13 is an unknown quantity at this point
HIS CAR IS A 93 CIVIC EX WITH A 99 B18C SWAP. PRETTY MUCH STOCK BESIDES I/H/E.
Old Sep 11, 2004 | 12:53 AM
Cpt. Non-Spell's Avatar
Cpt. Non-Spell
Speak&Spell Anyone?
Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell
buy a new ecu......
Old Sep 11, 2004 | 06:41 AM
BIGBALLS's Avatar
BIGBALLS
eg master
BIGBALLS is an unknown quantity at this point
check your distributor
Old Sep 11, 2004 | 05:17 PM
HatefulMechanic's Avatar
HatefulMechanic
The Pro to call.
get a new ignition switch. NAPA carries them.....its common in that particular model.
you gave it away when you said you could hold the key in the start position and it runs, but in the run pos. there is no lights in the cluster.
new switch is about 125 (getting a junkyard or used on will only band aid it,.....you will have to do it again.) and takes a novice about an hour to install.
i will just say this: i have installed about ten of them in the last year.
Old Sep 12, 2004 | 09:12 AM
JOE-C's Avatar
JOE-C
will it come with a new key or is it a little past that ?
Old Sep 12, 2004 | 10:34 AM
HatefulMechanic
The Pro to call.
no. just the switch
Old Sep 18, 2004 | 06:09 PM
pimpingreen13
hey whats up I was looking at his car and it used to be an automatic converted to 5spd is the switch different cause we got a switch and it was differrent than the one he had. his was all spliced up so I'm guessing they are different and the rigged it up to work? Any info would be appreciated. bump for my homey.
no. just the switch
Old Sep 18, 2004 | 06:30 PM
HatefulMechanic
The Pro to call.
shouldnt be different....last i checked, the differences were between years....trans didnt have anything to do with it...
a rigged honda? say it aint so....
