DA acting funny
Old Jul 7, 2006 | 12:23 PM
DOHC crx VTEC's Avatar
DOHC crx VTEC
DOHC crx VTEC is an unknown quantity at this point
Default DA acting funny
My friend Just swapped a b20 in his integra, and after wards. On occasion it wouldn't let him rev past 4,000 rpms like it was hittting a fuel cut.But now it wont even let him move the car and sometimes when he revs itll shut off. He also does have a remote start alarm system. When He turns his key on the check engine light goes CRAZY and you can hear some kind of relay clicking. I think it may be the fuel pump relay? Going bad becuase its acting like it hits a fuel cut and at the same time his tach (factory in dash) goes crazy. Any ideas?
Old Jul 7, 2006 | 02:28 PM
92EH3's Avatar
92EH3
92EH3 has disabled reputation
Default Re: DA acting funny
replace the main fuel relay there known for goin bad in the DA
Old Jul 7, 2006 | 02:31 PM
DOHC crx VTEC
Thanks, I'm unsure of where the main fuel relay is located in the DA. Specific location if you could...
Old Aug 7, 2006 | 06:38 PM
1evilgs's Avatar
1evilgs
Pong It Up Bitches
1evilgs is an unknown quantity at this point
Main fuel relay is behind the, plastic panel that the coin tray is in just remove that panel and its a big brown relay with a harnes plugged into it you can't miss it.Thats more than likely the problem.
Old Aug 8, 2006 | 07:14 PM
sircrx's Avatar
sircrx
Boost is Better
sircrx sircrx sircrx sircrx sircrx sircrx sircrx sircrx sircrx sircrx sircrx
also check your ground that is on the water pump housing. Many many times ive seen people leave it loose!
Old Aug 8, 2006 | 07:25 PM
DOHC crx VTEC
o damn, sorry for not updating. Prob was fixed longggg time ago
Old Aug 8, 2006 | 07:40 PM
sircrx's Avatar
sircrx
Boost is Better
oh sorry i was just browsing so what was it. so I can add it to my memory for fixes
ravenracer
Jun 15, 2008 07:36 PM
1aznTT
Oct 26, 2007 10:32 PM
BeefCake
Nov 2, 2006 06:27 PM
White Pinoy
Aug 12, 2005 02:24 PM
