car wont start help????
my roomate has a 94 integra non-vtec... he did a complete tune up(new radiator,plugs,wires,dist,rotor and cap) after he installed all of this he proceeded to start the car, and it did.. it ran for like 5 min and then randomly shut off? and now it wont start at all? he has gas, and it is turning over.. but just no spark? any suguestions?
thanks in advance
thanks in advance
recheck everything, check your rotor to make sure the screw didnt come loose or whatever, and his coil might be bad if he didnt replace that, just double check everything you replaced........
Originally posted by 0psi
Are you 100% sure that you don't have spark?
id do what more impatient said and double check everything you replaced. check and recheck your plugs and wires and everything related.
